thomaskuhn
Computer
- Sep 20, 2010
- 12
I am currently working to improve a product of ours that is a rugged, embedded, man wearable computer enclosure. Our customer would like to implement an audible alarm or better yet, a speaker to play prerecorded audible warnings.
The current design is a simple 3" x 6" two piece machined aluminum case which is currently packed pretty tight to fit much additional hardware. Most wall thicknesses are 0.07" In looking into solutions, two items came to to front, first being a audible transducer made by NXT. This would simply be adhered to the inside lid, and is designed to use the surface itself as a speaker surface. This would eliminate any additional openings, but might not perform as desired. The second product from Murata is a super thin Piezo speaker VSLBG1914E1400-T0. It is ultra thin but seems to be dificult to mount externally or in a recess. The third option is to have a opening in the case in which to surface mount a traditional speaker or Piezo. The issue with this is concern over MIL-STD-810 and MIL-STD-461 EMI issues that have to be dealt with with an additional opening.
Could anybody give some good design ideas or products to get audio on this system? In particular, sealing a audio speaker to IP67, case holes and mounting for a Murata type product, externally?
