okay, since most probably have not heard of Sous Vide (if it hadn't been for in-flight magazines, I wouldn't have), here's a primer:
One of the available Sous Vide machines is the SousVide Supreme, which retails for $400 or more, not counting a vacuum sealer.
My wife has a crock pot (an insulated container with thermostatically and timer-controlled heat source), but it only has 5 settings, and the lowest one, warm, seems to reach steady state at about 129 deg F. (I'm still letting it stabilize to be sure) The next step up, labeled "10 hours" reaches steady state at 201 deg F.
So task number one is to find a way to hit the right steak temperature (135F) before grilling. some ideas:
- insulate the tub of cooking water from the tub of heated water, so that the steady-state temperature of the cooking water is 65deg lower, perhaps by nesting a couple of plastic bowls to leave an air gap, and floating them in the heated water.
- find a way to circulate a small amount of cooler water into the bath, to lower the steady-state temperature.
- open up the crock pot and modify the circuitry to change the "10 hours" setting to a "Sous Vide" setting.
comments?
comments?
