Engineering Design for Anhydrous Hydrogen Fluoride (AHF) Storage System
CHemEnthusiast
Chemical
Mar 16, 2014
1
Dear all,
Currently I'm working on preliminary concept development for Anhydrous HF storage facility at ambient condition (ambient temp varies between: 24-45oC throughout the year) in our plant. This AHF will be received in ISO tankers from outside supplier.
What would be the safest and most economical industrial practice for AHF storage facility.
[li][/li]I mean one Carbon Steel MOC tank for bulk AHF storage inside a bund wall arrangement followed by one same capacity empty tank as stand by or for emergency use followed by another empty tank which will acts as a dump tank for the first two tanks in case of pressure relief. Is this configuration is feasible or is there any better way?
[li][/li]Canned centrifugal pumps are preferred for filling and unloading AHF. What precautions need to consider in terms of choosing right pump MOC and suitable valves in the transfer lines?
[li][/li]These three tanks will be maintained under inert atmosphere by using dry nitrogen. Tank vent will be connected to dedicated scrubber system with aqueous NaOH as scrubbing solution.
Please suggest any other safety aspects which need to be considered for this AHF storage and transfer facility.
Thanks in advance for your time and valuable suggestion.
Ravi
Almost all the manufacturers of highly hazardous chemicals provide guidance for handling and storage of those chemicals, and this guidance covers all the questions you have asked. You should be able to find this by doing an internet search.
And for these chemicals I would want someone else responsible for those decisions.
Our HF supplier basically gives us a very short list of acceptable equipment, if we don't use it then he won't supply to us.
See the recommended practices found on the website for "Hydrogen Fluoride Industry Practices Institute". That's an organization of HF manufacturers which publishes safe handling/design guidance.
