ENGINEERING TO TRUE STRESS VS STRAIN DATA 2
David Browne
12
Hello all,
I have a set of mechanical tensile test data in which I wish build material models in ANSYS.
I have Tensile Strain (mm/mm) data and Tensile Stress (MPa) data. These are Engineering Stress/Strain values provided by our testing house (raw data).
I am however looking for True Stress/Strain values to input in to ANSYS.
The tensile strain data only goes up to 2% strain due to limitations of the extensometer.
This therefore results in the tensile strain data going up to 2% strain then no further data is available for the remaining extent of the curve - so no information on the 2% to 100% strain ,or to break off point.
I do however have UTS and break off point information, load, original specimen area and % area reduction, initial and end length of test sample.
I need true stress and strain data for the data when the extensometer is removed to the end point- i.e. from when the data set limits at 0.02 Strain onwards. Could I simply extrapolate the data then convert to true stress/strain?
Thanks in advance.
You will need to know the changes in cross section to calculate true stress.
In the absence of anything better I find the following works well:
True Strain = Ln (1 + Engineering Strain)
True Stress = Engineering Stress ( 1 + Engineering Strain)
Thank you folks.
I managed to calculate true stress and strain using σ = Load/FinalArea and ε = ln(Ao/A) respectively then just interpolated from the last data set to the newly calculated values. Looks like this:
David.
