Again thanks for your comments:
The uP DS5002 does BUS encryption and the CODE and DATA store are encrypted. And yes, different boards will have different encryption keys on the uC.
I need a PCB board that can run security algorithms and keep security keys inside.
This can be used for instance for PC secure communications across internet for individuals as well as for companies.
let me call it (no name yet) secBoard.
On the secBoard there will be session keys as well as master keys and it is meant to work for 10 years (the usual figure although I do not why always this number
The DS5002 is not the TOP security! It is a nice uC but can be broken. It is not easy and not everyone can do it of course.
Security is more a matter of trust. Every system might be broken someday and of course when I say 10 years I must take this in consideration!
Tipically when designing security hardware we must think like the comment from IR stuff and we have to look for the security criteria to follow.
From my research on the internet and from what I have heard here I come to the following conclusions:
1) Software if extremely important!
2) EPOXY with special characteristics is very good for tamper detection and attack delay
3) Envelope detection is "the cool feature
Why it is important to make the attack longer!? Well because if one secBoard disappears or has tamper attack evidence the the master key must be changed as quickly as possible! By keeping the session keys changing often will prevent recorded messages to be broken!
"If the circuit is not powered up, then there is nothing t probe." remember that if no protection on power off someone can get to the PCB and broke the protection! Then it is easy to turn off the power!
"You seem to want a lot of protection for very little money."
) Yes but that is the life of someone that wants to do soemething
if I was IBM probably any security product less that 10000€ would be considered very strange
So in conclusion I am looking for "nice" solutions.
For the envelope I haven´t found anything!
Also I do not know if it is very feasible to disassembly one PCB to reach the inner tracks!?
One cool solution can be tilt sensors but this must be used carefully or else.....
