kc27315
- Aug 21, 2009
- 34
Considering Bernoulli's Equation, the Total Head should be the sum of the Elevation/Velocity/Pressure Heads at each point. My EPANET question is this: Is Velocity Head included in the computation of "Total Head" at a given Node? If so, which velocity is used? One of the upstream velocities? A downstream velocity? Average of those? Also, if it doesn't include velocity head, why not?
I've attached an example screen shot, and running a quick calculation shows that 4552+77.88*2.31 ≈ 4731.9 which is very close to 4731.73 ft of total head, so I'm imagining that maybe the Total Head doesn't include velocity head...
Hopefully I'm asking this in the right place. If not, I apologize and please delete.
Thank You!!
Thank You!!
