CarbonMike
Materials
- Sep 29, 2009
- 10
I have a problem with vacuum degassing of epoxy resin (300-500mPas viscosity) before resin infusion. After mixing I put cup into vacuum chamber and make 28,8" of vacuum (I'm in 1000feed above sea). I can see that the bubbles are forming and rising. Lot of them will pop, but I still have lot of them in epoxy after 10-15min degassing. Is the vacuum level low for perfect degassing? Microbubbles in epoxy cause my problems with dry spots in the carbon weave.
I don't have any leaks during infusion, holding 28,8" vacuum for a day with pump shut down.
Thanks for your help.
Mike
Mike
