Equal or similar faces of two Solid Bodies
OlafU
Automotive
Jan 31, 2012
19
Hello all.
I need to find and determine equal or similar (with a certain tolerance) faces between two different bodies.
I have already a Code where I can achieve this with single sheet bodies (with one face each).
Now I am Looking for a similar way to do this for Solid Bodies (Maybe also for Sheet Bodies with multiple faces).
OlafU
NX12.0.2
Have you looked into "model compare"? It does a good job highlighting identical/changed faces between 2 bodies (in different part files). I don't know that it has a compare tolerance setting, though.
www.nxjournaling.com
Yes, you are Right, thanks.
In addition, I didn´t mentioned it in my first post: If equal faces or similar faces were found, than certain faces attributes and/or properties linke face name should be copied from the one face (like a seed face) to the other face (a Kind of target face, that has None of These attributes and properties).
Cheers
OlafU
NX12.0.2
