Just speculating on the likely shortest engine for a given performance (based on equal swept volume & maximum revs):
V4 would have 2x larger bore diameter vs. 3x smaller bore diameter for V6
V4 would need shorter stroke to achieve similar revs to V6, so slightly larger bore again
'lost' length (bank stagger, FEAD length, Flywheel length) likely to be similar
Feel free to challenge any of the above / provide real data. Also, which might have lower friction, thus skewing the 'equal' swept volume / revs comparison.
Thanks, Ian
Thanks, Ian
