connor1406
Hi everyone,
I am quite new to Abaqus and FEM software in general. I am trying to model a thick walled pipe (closed) in Abaqus. The way I have been doing this is extruding a solid pipe section and constrain one end (BC) in the axial direction only (to allow for radial and hoop expansion). I have then applied a uniform internal pressure to the pipe and the associated axial pressure (calculated for a closed thick walled pipe).
The problem with the model is the way the pipe is deforming, it does not seem to make physical sense. I am expecting radial and hoop deformation to be uniform. I am unsure why this isnt working, could someone please outline how to fix this problem so i can have a well behaving closed thick walled pipe? (I am currently trying equation constraints)
Thank you! Please ask any questions and I will respond asap.
