RuneRRA
- Nov 13, 2014
- 5
Hi I would like to calculate the flow and pressure distribution in a pipe with multible inlets.
The pipe is basically a 25 m long straight pipe, Ø500mm, with 10 gaps (Ø110) drilled in to its side. at the end of the pipe a ventilator is sucking the air through the pipe at a flow of 2000 m3/h.
I would like to calculate the corresponding flow through each gap and the pressure below each gap. I know i need to use some kind of iteration process (proably based on Bernouilli's equation and the minor losss coeficient for the gaps and the loss coeficient for the tube) but it would be nice to se some one who has descriebed how this is done in practice.
Can anyone refer me to where i can see such description? a book/ homepage or alike.
Thanks in advance
