HI
I have problem to determine the nozzle rating for equipments. I work in piping dept., when I receive Process datasheets for drums, exchangers and towers from Process dept. and I have to determine the nozzle ratings. The contradiction is that there is equipments with design pressure and design temperature (mention in Process datasheet) less than connecting process line. With this conditions, shall I assume all nozzles with the higher rating? or I can just consider the connecting nozzle with higher rating and the others as per less rating?
Thanks in advance
Thanks in advance
