Excessive Pump Suction Nozzle Loads 1
FlashPurp
Industrial
May 10, 2024
14
I am working on stress on pump suction piping coming from a tank. I am seeing high moments and nozzle loads on my pump during hot and cold operation. I believe the issue is with how my header is growing and contracting during the 2 cases, so I was wondering the best way to restrain without transferring loads to the pump nozzles? Or would it be best to reroute the header to add flex and reduce movement?
Information:
Fluid: Water
Low Temp: 30 F; Hot Temp: 150 F
Design Pressure: 50 PSIG
Material: A312 TP304
Header Size: 18" SCH 10S
Branch Size: 12" SCH 10S
Nozzle Size: 8"
This is the layout I currently have it:
Movement during cold operation:
Movement during hot operation:
Agreed. In that example you can see the stresses go down but the nozzle loads still too high. Its not until the expansion loop is added that the nozzle loads are acceptable.
Thanks for everyone's insight, it is very informative.
@RVAmeche I agree as I look through different forums and there's always an agreement that the high loads aren't always realistic due to different factors (gasket compression, nozzle stiffness being lower than Caesar's typical anchor). I just wish there was some sort of guide or standard to modeling that shows this to create more realistic model.
@KernOily unfortunately we do not have any FEA licenses. I am a little confused on the pump nozzle stiffness approach with 1E5 and why I would want 1". Say for example API 610 is limited to 0.01" would I be able to use the allowable loads to calculate stiffness from that? K=F/d?
FlashPurp
Since this is still open I would like to add some comments.
This was a poor layout to start and having hot cold scenarios with 3 alternating running pumps is a very challenging task.
Looking at the output, the exaggerated displacement graphic shows the moment arms issue with the two outer pumps. For your curiosity run a model without the tank run leg and do your hot cold alternating pump scenarios with just the pump feed header. can you even get the pumps to work. Resolve the 3 pump layout, then fix the tank leg line to not apply excessive load or displacement into the pump header.
Good luck resolving.
Thanks @Piper Mike I'll try working it like that one step at a time, I assume I'll still anchor as a boundary condition before adding my tank leg?
