Equivalent Grounded Spring Element in Ansys?
bluesyd
6
Hi all,
I used to use grounded spring elements in Nastran to simulate elastic boundary conditions for a given structure. What would be the equivalent element to use in Ansys? If there isn't one, how do you normally model elastic boundary conditions in Ansys?
Thanks,
anne
COMBIN14 should be what you need (spring/damper). You can't directly tell the program that it is "grounded", however it is sufficient to fully-restrain the destination node.
Thanks cbrn, again:) Just saw your reply to my other question regarding the IDs of nodes!
cheers
anne
