DaveAtkins
- Apr 15, 2002
- 2,893
I am confused by Equation 9.5.5.2.1-1 in ASCE 7-02. This equation states that Cs = SDS/(R/I), "when the fundamental period of the structure is computed." First of all, fundamental period does not enter into this equation, so why does it matter? Second of all, does this mean that in order to use this equation for Cs, I must limit T to Cu*Ta, as specified in Section 9.5.5.3?
I have an actual situation I am dealing with--in Seismic Design Category B. Cs as computed above is less than
SD1/(T(R/I), if I assume T = Ta. So I would like to use Cs as computed above. But I performed a dynamic analysis on RISA-3D, and T for some of my braced frames is greater than Cu*Ta. So I think I need to stiffen up my braced frames, but I am not sure.
The other thing that confuses me is that I believe in ASCE 7-98, it did NOT have that statement "when the fundamental period of the structure is computed."
DaveAtkins
DaveAtkins
