HeavyCivil
- Aug 5, 2009
- 184
I'm curious if anyone has approximated a modulus of subgrade reaction for rigid foam insulation beneath concrete slabs.
I see regular foam board used in residential construction frequently - not the 40-100 psi hi-test variety that is preferred for under slab use. I am curious how you would compensate in design, other than assuming some arbitrary and low value for k.
