Tmoose
- Apr 12, 2003
- 5,633
A foundry is proposing repairing small defects in 3000 lb steel rough machined castings with ER70S-3 TIG welding rod.
The castings are ASTM A27 Gr 60-30. Normalized at 870°C. Actual 529 MPA (76 ksi) tensile strength. Probably ~ 39 HRC .
Way "better" than the ASTM A27 Gr 60-30 60 ksi/415 MPa (~ HRC 31) minimum specification.
We reportedly have had problems in the past when finish machining similar parts with weld repairs.
So we are forbidding weld repairs on surfaces requiring accurate finish machining.
Per Lincoln their LNT25 ER70S-3 rod typical "as welded" tensile strength is 560 MPa / ~ 81 ksi.
In one common chart that equates to ~ HRC 41.
39 (actual casting) and 41 HRC (typical weld) don't sound that far apart to me. Elongations are 35% ( casting ) and 22% ( typical weld)
I'm thinking those troublesome castings //may// have been closer to the ASTM Minimums, so the 10 pts difference in hardness may have been the issue in days of yore.
Comments?
thanks,
Dan T
Comments?
thanks,
Dan T
