Cathy039
- Sep 15, 2017
- 14
SUBROUTINE DLOAD(F,KSTEP,KINC,TIME,NOEL,NPT,LAYER,KSPT,
1 COORDS,JLTYP,SNAME)
INCLUDE 'ABA_PARAM.INC'
DIMENSION TIME(2), COORDS (3)
CHARACTER*80 SNAME
PI=2.*ASIN(1.D0)
PARAMETER(DENSITY=1024D0,GRAVIATION=9.81D0,RADIUS=0.15D0,MINRADIUS=-0.15D0,RADIUS1=20)
CALL uwave(v,a,pdyn,dpdyndz,surf,lpdyn,lrecompute,luplocal,
1 lupglobal,lsurf,ndim,xcur,xintmed,grav,density,elevb,elevs,seed,
2 nspectrum,freqwamp,time,dtime,noel,npt,kstep,kinc)
MERGE=COORDS(3)-SURF
IF(MERGE.GE.RADIUS) THEN
MERGE=RADIUS
ELSE IF(MERGE.LE.MINRADIUS) THEN
MERGE=0.D0
END IF
THETA=ACOS(COORDS(3)/RADIUS)/180
AREA=THETA*PI*RADIUS**2-MERGE*SQRT(RADIUS**2-MERGE**2)
F=DENSITY*GRAVIATION*AREA*PI*RADIUS1
RETURN
END
SUBROUTINE uwave(v,a,pdyn,dpdyndz,surf,lpdyn,lrecompute,luplocal,
include 'aba_param.inc'
dimension v(ndim),a(ndim),xcur(ndim),xintmed(ndim)
dimension time(2),freqwamp(2,nspectrum)
parameter(pi=3.14159265358979d0,two=2.0d0,abig=1.d36)
parameter (const2=2.d10, twopi = 2.d0*pi )
luplocal=0
lupglobal=0
if(lrecompute.ne.0) then
! Only stochastic analysis with UWAVE can have lrecompute=1
! The user must set other flags accordingly; see User's manual.
else
! For regular Aqua analysis with UWAVE, lrecompute=0 always
! Wve definition for a single Airy wave component:
! Phase angle of waves: in radians
phase=0.0d0
! Wave travel direction:
xdir=1.0d0
ydir=0.0d0
! Period, wavelength, wave number, wave height, frequency:
period=15.d0
waveln=224.64d0
wavenum=twopi/waveln
wavehgt=1
freq=twopi/period
if (lsurf.eq.1) then
! Calculate the instantaneous water surface only, no
! wave kinematics are required:
wtp=-freq*time(2)+phase
sn=xdir*xcur(1)
if (ndim.eq.3) sn=sn+ydir*xcur(2)
termt=wavenum*sn+wtp
surf=elevs-wavehgt*cos(termt)
ENDIF
ENDIF
return
end
wave2.f(7): error #6236: A specification statement cannot appear in the executable section.
PARAMETER(DENSITY=1024D0,GRAVIATION=9.81D0,RADIUS=0.15D0)
compilation aborted for wave2.f (code 1)
Abaqus Error: Problem during compilation - wave2.f
Abaqus/Analysis exited with errors
What is the problem? Thank you very much!
CHARACTER*80 SNAME
PI=2.*ASIN(1.D0)
MERGE=RADIUS
MERGE=0.D0
END IF
RETURN
END
luplocal=0
lupglobal=0
else
phase=0.0d0
xdir=1.0d0
ydir=0.0d0
period=15.d0
waveln=224.64d0
wavehgt=1
freq=twopi/period
sn=xdir*xcur(1)
ENDIF
ENDIF
return
end
