Hi all, me again
When my model only has elastic behavior, everything is fine. While I tried to input plastic behavior as below, the job is aborted due to errors. [SI unit:N, mm]
I first run the model in "Static, General" mode, after job abortion, I run the model in "Static, riks" mode.
The error first said "too many attempts made for this increment". Then I tried to increase time incrementation no.
Then the error said "Time increment required is less than the minimum specified", then I tried to adjust min value as below. But the error still said"Time increment required is less than the minimum specified" even I put on Nlgeon
There are also other warning too
I tried different sections, but once I input plastic behavior, the job will be aborted. dont know what to do
