Error Code 529697949
Aravindkj
Bioengineer
Jun 15, 2014
25
Hello Guys,
I have uploaded the right image.
In my model I have a block. The side plates are fixed to the central block using a nail or peg. The side plates are encastre at the bottom and a pressure is applied on top of central block.
When I use Tie constraint between (plates and central block, Pegs and Central block and peg and plates) it works fine.
I need to have a frictionless contact between the central block and the plate. I used Surface to Surface contact(standard),Sliding formulation as (surface to surface) and Interaction property as Tangential behavior (Frictionless).
I get the following error.
ERROR: An error occurred during a write access to
C:\Users\ajay902\AppData\Local\Temp\ajay902_New_trial_1_3200\New_tria
l_1_stdSolver.local_0 file. Check the disk space on your system.
Please help me.
P.S: I would like to apologies for the wrong image I have attached in my previous post.
 http://files.engineering.com/getfile.aspx?folder=4e4e3140-17a2-4ca6-abe1-5acc5913a83e&file=1.png
Your application, which you have not identified, is asserting that your computer's primary disk drive is full.
You can try defragmenting the drive, but you may have to buy a bigger one, or erase the junk from the one you have.
Mike Halloran
Pembroke Pines, FL, USA
There are forums for a number of different CAD programs. Next time, you should try posting in the one for your particular CAD program.
TTFN
faq731-376
7ofakss
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Thank you so much for your reply.
However for the same model I have
Tried using tie constraint and it ran successfully.(after your suggestion)
Sorry for posting it here. I have simplified
My bone model as blocks to learn abacus.So I thought I can post it here. Really sorry.
