Error Extracting Surfaces from a Search
jzecha
Aerospace
Jan 20, 2016
236
I am running into a an error I have never seen before.
I want to search a product for visible faces, extract those faces, and join them all together.
The code fails on the oPart.Update, saying "Update Failed"
When I look at what was created in the model, it creates all the Extracts, but they need updated.
When I go to edit one of the extracts, it pops up with an Error stating:
Update Failed
An error occurred in GenericNaming treatment, the selected element may be not piecewise connected.
Please select another one.
Can someone please help me figure out the correct way to code this?
Code:
            Dim AssyFaceSelection As Selection
            Set AssyFaceSelection = oTopProductDocument.Selection
            AssyFaceSelection.Search "(Topology.CGMFace & Visibility=Shown),all"
            Debug.Print AssyFaceSelection.Count
            Dim oInitialJoin As HybridShapeAssemble
            Dim FaceCount As Integer
            FaceCount = AssyFaceSelection.Count
            Set oInitialJoin = oHybridShapeFactory.AddNewJoin(Nothing, Nothing)
            oInitialJoin.SetConnex (False)
            For X = 1 To FaceCount
            Set oSelectedBodyRef = AssyFaceSelection.Item(X).Value
                Set oSurfExtract = oHybridShapeFactory.AddNewExtract(oSelectedBodyRef)
                    oSurfExtract.PropagationType = 3
                    oSurfExtract.ComplementaryExtract = False
                    oSurfExtract.IsFederated = False
                    oSurfExtract.Name = "Part Surface " & X
                    oHybridBody.AppendHybridShape oSurfExtract
                    oInitialJoin.AddElement oSurfExtract
            Next
            oHybridBody.AppendHybridShape oInitialJoin
            oPart.Update
Perform the operation manually, this will bring up a dialog with description of the error.
When I do this manually, I do not have a problem.
I perform the search, select all of the results.
Then click extract, the 27 results automatically populate into the "Elements to extract field" and I can hit "OK" and it works as expected.
Recheck if extract options that you check in code match those set with UI command.
Have you declared oSelectedBodyRef as Reference?
I checked and even recorded my approach and the extract settings are correct.
Also verified I declared it as Reference.
My best guess is that it has something to do with when I record it, it uses CreateReferenceFromBRepName.
The recorded section of the code I do not know how to interpret is:
Code:
Dim hybridShapeSurfaceExplicit1 As HybridShapeSurfaceExplicit
Set hybridShapeSurfaceExplicit1 = hybridShapes1.Item("Surface.7")
Dim reference1 As Reference
Set reference1 = part1.CreateReferenceFromBRepName("RSur:(Face:(Brp:(GSMBiDim.7;%2);None:();Cf11:());WithPermanentBody;WithoutBuildError;WithSelectingFeatureSupport;MFBRepVersion_CXR15)", hybridShapeSurfaceExplicit1)
Maybe I am not understanding exactly what you are explaining.
I can Run this on a simple product Called "BoundingBox_Test_Product" that has a few random angles and plates in it.
It also has a part called "BoundingBox" that this code is trying to build the Extracts into.
This macro fails on the oPart.Update at the end.
It creates all the extracts, but they need to be updated.
When I go to click on one, it has the same error as before.
"Update Failed
Please select another one."
Here is the full simplified code I can run.
I really appreciate the help, Please let me know what I am doing wrong
Code:
Sub CatMain()
    Dim oDocuments As Documents
    Set oDocuments = CATIA.Documents
    Dim oTopProductDocument As ProductDocument
    Set oTopProductDocument = oDocuments.Item("BoundingBox_Test_Product.CATProduct")
    Dim oProduct As Product
    Set oProduct = oTopProductDocument.Product
    Dim oPartDocument As PartDocument
    Set oPartDocument = oDocuments.Item("BoundingBox.CATPart")
    Dim oPart As Part
    Set oPart = oPartDocument.Part
    Dim oHybridBodies As HybridBodies
    Set oHybridBodies = oPart.HybridBodies
    Dim oHybridBody As HybridBody
    Set oHybridBody = oHybridBodies.Item("Bounding_Box_Product")
    oPart.InWorkObject = oHybridBody
    Dim oHybridShapeFactory As HybridShapeFactory
    Set oHybridShapeFactory = oPart.HybridShapeFactory
            'Set AssyFaceSelection = oPartDocument.Selection
            Dim hybridBody1 As HybridBody
            Set hybridBody1 = oHybridBodies.Item("External References")
            Dim hybridShapes1 As HybridShapes
            Set hybridShapes1 = hybridBody1.HybridShapes
            Dim oFaceExtract As HybridShapeExtract
                                Dim oSurfExtractRef As Reference
                                Set oSurfExtractRef = AssyFaceSelection.Item(X).Value
                                Set oSurfExtract = oHybridShapeFactory.AddNewExtract(oSurfExtractRef)
            Next
            oPart.Update
ErrorHandler:
End Sub
Are gou saying that the resulting join and original faces are located in different CATParts? If so, you can't reference geometry from another document with VBA.
I suggest creating extract and join features in original part and then copying join to target part as result with Selection.PasteSpecial
That explains it, it wont work because they are in different parts.
For what I am doing, I will just have to figure out a different way, I do not want to create extracts in every part.
Thanks for the insight, I had no idea you couldn't do that.
