OkelloEng
Industrial
- Apr 28, 2022
- 4
Hey All,
So basically I've completed my FEA model and ran it with success with topology optimization running also successfully.
Afterward, I wanted to change a few things in my FEA model and ran the analysis job successfully then I used similar Topology Optimization configurations but this time for the new FEA model and the below error pops up, it does not explain anything. Does anyone know why? I highly suspect it is a software/hardware thing rather than the analysis thing but I really appreciate your input if anyone had this error before. Interestingly, I fired up the old FEA model and then Topology Optimization, it worked successfully but happens only when I run the new FEA model.
I've referenced a similar case to me but nobody answered it and it was closed : thread1630-484138: Optimisation error
Kind regards,
OkelloEng
[16:33:37.559203|tosca_python] Solution failed!
[16:33:37.559203|tosca_python] Module abaqus failed
[16:33:37.576156|tosca_python] Tosca Structure failed to run the optimization task
Optimization process failed with an error.
Kind regards,
OkelloEng
