Bogdan1985
Hi, it's me again.
I designed parameters and relationships. Everything is fine. I clicked "Design Table"
and checked "Create a design table with current parameter values"
But the button in the tree is missing. I tried to open the sheet from the location
and a new error message shows up in the window:
"The design table contains no data or its file wasn't found (you can use Edit Properties to change the source file}"
See attached image.
See attached image.
