Error on VBS 1
lapek
Aerospace
Aug 26, 2013
37
hello guys
I have this code, and when running in in CATIA it gave me an error, hope you can help me
Dim oFoundEdges
Set oFoundEdges = New Collection '(the component active x can not create the object "collection")
For j = 1 To osel.Count
sEdgeName = osel.Item(j).Value.name
Dim aEdgeName
aEdgeName = Split(sEdgeName, "face")
sEdgeName = "face" & aEdgeName(UBound(aEdgeName))
If sEdgeName = "*" & sFaceName1 & "*" & sFaceName2 & "*" Then
Dim Edge
Set Edge = osel.Item(j).Value
oFoundEdges.Add Edge
iFoundEdges = iFoundEdges + 1
End If
Next
osel.Clear
If Not iFoundEdges = 0 Then
For j = 1 To oFoundEdges.Count
osel.Add oFoundEdges.Item(j)
Next
data_file.WriteLine "Numero de aristas"
data_file.WriteLine (iFoundEdges)
data_file.WriteLine "--------------------------------------"
'Else
'MsgBox "La figura no tiene aristas"
End If
I don't know what to do,
thanks
Dim oFoundEdges as New Collection
Eric N.
hi, itsmyjob
thank you so much for your answer
I tried that already, but on VBS does not accept any as ...., so I had to erase it,
at this point I don't know what to do.
hope you can guide me trough
thanks
dont know if you can use collection in VBS... works on VBA
Eric N.
thak you for your answer I found that collection can not be used
I use CreateObject("Scripting.Dictionary") and it works perfectly
thank you for your help
can you elaborate ?
Eric N.
I don't understand the question
if I can elaborate de code? or de collection?
can you share your solution?
Eric N.
oooo yes sure here is the code
Dim oFoundEdges
Set oFoundEdges = CreateObject("Scripting.Dictionary")
Dim aEdgeName
If InStr(sEdgeName, sFaceName1) and InStr(sEdgeName, sFaceName2) Then
Dim Edge
oFoundEdges.Add j, Edge
End If
Next
osel.Clear
Next
'Else
End If
I hope it can help
thanks
Eric N.
