Error Recovery: Incorrect object for this operation
VW181
122
Hi All,
Today we had some network problems.
Some people had problems working in NX and others didn't, like me. At least, i thought so.
While saving i got no errors or whatever.
But now I've restarted TC and NX and try to open the assembly i was working on i can't open it.
I get the error message:
Error recovery completed for the following error:
Incorrect object for this operation.
I can open this assembly "Structure only". But when i check parts/sub assembly to load some will load and others give the same error as mentioned before.
Some of these part I can open directly in NX, and others not.
Or an already loaded part will "unload" when i load an other part.
I tried "Update Structure" in the assembly navigator, but this also doesn't work.
Any other suggestions?
Or is my assembly lost...... :-(
Using NX 8.0 and Teamcenter 8 on Windows 7 (64)
This problem is solved after contact with GTAC.
It was probably caused by the loss of connectivity from an constrain. This can lead to a chain reaction in whole the assembly.
This is solved to load the assy "structure only" and load all parts/sub assy's one by one and note all the parts with load problems.
Close the assembly.
Load all parts/assy's with load problems separately.
When all parts/assy's are loaded separately load the top level assembly "structure only". All already loaded parts should be visible.
Check all other parts to load them an save the top level assembly.
Hope this can help someone in the future.
(This error should be solved in Nx8.5 and 9 GTAC said)
