Hello everyone!
I have concern about ERV operation schedule.
ERV supply fresh air to the fan coil units in the building.
ERV will keep on running until all the fan coil units are turn off.
Now the problem arises when all the fan coil units are off, ERV will be off and if this situation remains for several hours during the day, there will not be any fresh air circulation into the building.
If we circulate fresh air in the building if will call the fan coil units to turn on as the O.A temp is low and it will add the heating load in the winter and cooling load in summer.
Any Suggestion.. how it can be controlled to circulate fresh air in to the building when all the fan coil units are off. We need to circulate minimum cfm into the building.
