pickler
Automotive
- Feb 21, 2013
- 90
I have a naturally aspirated 2.5L boxer 4-cylinder engine. I would like to estimate brake specific fuel consumption sweetspot for my engine at partial load (say +50% based on MAP readings). I do have a chassis dyno curve which i thought some one could use here to help estimate BSFC from. Basically this is a 16 valve boxer 4 cylinder oversquare engine with variable valve lift (Not timing). I have been told valve lift occurs at high loads and/or higher engine speeds and that one intake valve is always open.
I have attached the dyno graph. Looking at the dyno, the engine has a relatively flat torque curve for a 4 cylinder. Peak torque occurs at 4400rpm and peak horsepower at near 6000rpm. AFR stays stoich until just under 4000rpm. My estimates for BSFC sweet spot are 1500-2000rpm at 80% and 2000-2500 at 60% load, but i'm not sure how valve lift at higher loads affects BSFC.
