Estimating friction angle of clay 2
temee
Geotechnical
Nov 22, 2017
Hi
Is it possible to estimate friction angle of clay for drained stability calculation? I heart that there is some software which is able to estimate friction angle based on clay-size fraction and some other parameters.
Thanks fattdad - but as you imagine, one must be careful about how the phi values were determined; they are not all the same! Trust all is well!
Thanks Okiryu. I've attached a few charts that I was given in a lecture by Wesley (Okiryu - same as I sent to you privately). Wesley (from Kiwiland) worked quite a bit in Indonesia and with residual soils. He puts forth the concept of "where does the Atterberg limit of a sample fall relative to the "A-line" - i.e., in a parallel sense to it. He figures this is more important in deriving behaviour than just plotting on the chart. I think that his graphs show this. [cheers]
 http://files.engineering.com/getfile.aspx?folder=84b3d937-8132-4aa5-931f-becc9dd6d61b&file=Clay_Friction_Angle_vs_PI.pdf
BigH, thanks for the charts. I was also able to interchange some emails with Dr. Wesley. He was very responsive and helpful. Thanks again !
