bfuchs
- Feb 2, 2000
- 36
When you are designing a low voltage installation, how do you estimate, or what precautions do you take to make sure (if possible), that harmonics are not going to be a problem.<br>
Harmonics from equipment like :<br>
- variable speed drives<br>
- fluo lamps<br>
- office equipment<br>
- etc...<br>
Harmonics affect capacitors, currents in the neutral (triplens add up there unfortunately !), shorten the life of transformers, ... <br>
<br>
When do you oversize, when do you add filters, isolation transformers, double neutrals, ... How to determine the best solution ?<br>
<br>
Any ideas recommendations ?<br>
Thanks,<br>
<br>
Boris<br>
<br>
- fluo lamps<br>
- etc...<br>
<br>
<br>
Thanks,<br>
<br>
Boris<br>
<br>
