I wouldn't think this would give me as many problems as it has. I have a working spreadsheet that takes inputs, i.e. weights, springs, geometry factors and calculates wheel rates, damping coefficients, roll rates, tlltd, etc.
Most of the calculations have been verified, but I'm having trouble getting the wheel travel estimates under cornering to work out. Right now I'm working with a suspension that has softer springs and a very stiff bar in the front, soft bar in the rear. I've worked out all the wheel rates, roll rates and they match the numbers that I have from another source on this car.
I have a section on the spreadsheet that calculates suspension position at static, meaning how much the spring/damper compression, tire compression, overall chassis deflection, force in the spring.
Following this section, I have a set of calculations that are supposed to calculate wheel travel of the outside wheel at 1g. I am starting with the static wheel loads and adding the loads calculated from the lateral load transfer section (which I'm pretty sure are correct). I subtract the unsprung weight from this number, this is assuming that unsprung weight transfer is small and it is about 10% of the total weight transfer, so I think it should be alright. The sprung corner weight at 1g is divided by the wheel rate including the one-wheel bump arb rate to estimate the wheel travel relative to the chassis.
I am comparing this number to the estimated wheel travel based on the roll gradient. And they are greatly different. With the first method of calculation being much greater than the second.
So what am I missing? If I have the wheel loads, shouldn't I be able to relate that to suspension travel if I have rates and installation ratios for the springs?
If anyone has any ideas or any suggestions, I would appreciate it. I can provide more numbers and calculations if they would help. Thanks guys.
Tim
Tim
