sadato9224
Hi, everyone.
Title says it all. I checked the axial compressive strength of a compact W-shape column/beam in ETABS 18.1.1 and compared it to manual calculations based on AISC 360-10 Section E3 and E4. It seems that ETABS calculates the compressive strength differently than AISC 360-10 even though the design manual clearly has the same formulae as AISC 360-10.
I've checked the flexural, shear, and tensile capacities reported in ETABS and they are equal to those I've calculated manually. Only the compressive strength results given in ETABS are different.
I've followed the calculations exactly and changed the input parameters accordingly (K-factor, unbraced length, etc.) and the results are always different no matter what dimensions I use. Is anyone facing this issue as well or am I missing something?
