ETABS 2013 ERROR - Running out of Memory
redsun87
hi, i am facing the ETABS error which is 'ERROR IN DEFINING ANALYSIS MODEL ARRAYS. MAYBE RUNNING OUT OF MEMORY'.
Anyone facing the same problem?? have any solution for it?
Regards.
Thank you.
What is the computer configuration? The machine satisfy the demand of the ETABS?
Also the operating system is important if is 32bits or 64bits, special if the model is complex.
If you need some help you can sent me the model and I can run on my computer.
Good luck!
