dadomago75
- Mar 2, 2011
- 30
Hi everybody, please help me cause I'm getting frustrated with all these different explanations!
I read a lot about stiffness modifiers for shear walls (CSI website, ATKINS manual, Eng-Tips forum threads....), but I have some doubts about what they report because they say different things, and they look different to what is required by ETABS.
In wall's ETABS table is required to specify:
Membrane f11 modifier (supposed to be axial force along axis 1)
Membrane f22 modifier (supposed to be axial force along axis 2)
Membrane f12 modifier (supposed to be in-plane shear)
Bending m11 modifier (supposed to be bending moment about axis 1)
Bending m22 modifier (supposed to be bending moment about axis 2)
Bending m12 modifier (supposed to be torsional moment about axis 3)
Shear v13 modifier (supposed to be out-of plane shear)
Shear v23 modifier (supposed to be out-of plane shear)
and in CSI Analysis Reference manual at p.144 is specified that F11&F22 are axial forces along axis 1&2, F12 is shear within plane 1-2, M11&M22 are bending moments out of plane, and M12 is torsional moment, and V13&V23 are transverse shear out of plane, according with what I have written above.
If F11&F22 are axial forces, why in CSI website Link is stated that f11 controls EI? EI is obviously related to bending (so to m11&m22), whereas f11=f22 control EA (axial behavior), and f12 controls GA (in plane shear behavior).
Is it a mistake or am I missing something?
According to ACI318 and ATKINS I should I use m11=m22=0.7. And what about m12=?
And what about f11=f22=? I believe I should use 1 to account elastic shortening correctly. So, to take into account cracking for shear should I modify f12? and what is the value? 0.7 uncracked and 0.35 cracked?
And for out of plane shear v13=v23 should I use 1 because the shear within the thickness is neglectible (that’s why ETABS doesn’t allow me to change it)?
Furthermore, just thing if I decide to use a membrane element, which means m11=m22=0, what should be the values for the other parameters? what do you usually use, and where/how did you get them?
Thanks in advance for your help
PS sorry if I am honest
.....but I don't like ETABS at all!
![[wink] [wink] [wink]](/data/assets/smilies/wink.gif)
![[thumbsdown] [thumbsdown] [thumbsdown]](/data/assets/smilies/thumbsdown.gif)
