BrandonHo
- Aug 17, 2020
- 5
Hi guys, I am wondering if anyone who uses ETABS frequently have this kind of problem I am having now with ETABS columns design.
The results below shows all 0 for a 200x1000 column although it is not 0 from analysis results?
And then I changed it to 250x1000, it gets a bit normal but I dont get why it requires so much reinforcement? I did hand check and it doesn't require that much at all.
The strangest thing is when I check the analysis results for that column under this load combination the moment do not match the design moments above.
Does anyone have this problem with ETABS as well?
