ETABS Import Problem
odysseusky
7
Did a quick search, couldn't find anything, so here's the problem I am having.
Just installed ETABS v13.1.3, but I can't import any dwg or dxf files, always end up getting a dialog box with this message,
"Can Not Open File c:\xxxx\xxxx\xxxx.dwg"
I'm running AutoCAD 2014 on Windows 7 (32 bit)
Any idea how I can fix this please?
Thanks in advance.
Maybe it has something to do with the patch you've used. Try to export a dxf file to see what comes up.
My Father taught me to never disown poor people!
Having the exact same problem...
Any fixes guys?
make sure the dwg/dxf file isn't opened in autocad
if it still wouldn't work, try reinstall autocad with all of its components
Export your DXF using version Autocad2000 (See Autocad/Option/Saving)
Retry to import your dxf
Have they fixed this bug in the 2015 version?
2015 works fine for me. i think 14 will work too so long as u install all the components
Still getting this error in ETABS 2015. Does it need to be a certain AutoCAD file? As in 2007, 2010, 2014 etc?
Do DXFs work better?
I have the same issue.
I tried with several versions of autocad, doesn't work.
You need to have a full version of Autocad installed locally on your PC in order to be able to import DWG's direct into ETABS.
if you dont, then your only option is to use a DXF.
if the file will be imported is already open.You can take this messages.
1-save in DXF format
2-close the file
3-than import
