ETABS modelling question
snroland
I'm new here, so I'm not sure if I posted in the right section, but anyways...
I have one simple question regarding ETABS. Does anyone know what this thing means in my model? (see attached picture)
Thank you in advance! :)
Maybe someone else has seen it before, but I haven't. Things to try:
-Contact CSI, they're pretty helpful
-Might be an offset
-Might be a link
-Go through all the display options (the check box) and try switching them on and off until it disappears; then you'll know what it is
-Right click on the member and check the assignments. Then check one that doesn't have it. See if anything is different.
Unfortunately, I've tried switching all the display options on and off, none of them seemed to point out what it is. I might even think that it's a glitch at this point...
Thank you for the quick response though! Will try the other(s).
R
