Etching 304L
Hercules28
Materials
Nov 9, 2010
169
What etchant would you use for 304L. Grain boundaries.
Non electrolytic are preffered.
electrolytic oxalic acid is still the best.
If you don't want to mess with a power supply just use a battery.
You can try two things, a more concentrated oxalic acid may be good enough. Or a dilute HCl, however this may mess the rest of the micro up too much for you.
I'll check my list when I get back to the office.
Plymouth Tube
Just so you know,
I tried Marbles and it work great.
37% HCL and 7 gr CuSO4.
Swab for 5-10sec. Rinse with water.
Thanks for your suggestions. I will try the oxalic.
Mighty agressive etch for 304L. Marbles reagent is used for high end nickel-base alloys. I'll stick with 10% oxalic acid, thank you.
A number of the more aggressive etches will give good grain boundary definition in 304. But they also tend to produce a huge number of etch related artifacts that may be easily misinterpreted as defects.
Plymouth Tube
Oxalic is crude but effective, and very easy to use. Concentration is saturated, about 10%.
Sodium or potassium hydroxide also works well, at concentrations from 10 to 40%. Just beware of the impressive heat of solution that is generated when you mix it with water.
Radio Shack sells a variable voltage charger that is good enough for much electrolytic etching work. Also you don't need lab grade water - I have always used distilled water at the grocery store.
