Ethanol - Correction factor ? 2
AlexEss
Automotive
Dec 23, 2015
28
0
0
IT
Hi all
Hopefully a simple question for you -
I am measuring the ethanol content of a gas stream, using a hand-held analyzer.
The result is displayed in mg/Nm3 of Ethanol.. say, 400mg/Nm3 for example.
How do I determine the Carbon content ( mgC/Nm3 ) from my result ?
Is it a simple correction factor ?
I'm not a Chemist, so please excuse me if the question is dumb.
Thanks in advance for any replies,
Alexess
Considering ethanol C2H5OH, 1 mole ethanol, 2 moles de C
Molecular weight Ethanol: 46 g/mol
Molecular weight C: 12g/mol
Calculation : base 400 mg ethanol/Nm3 >>> 400/ 46 E3 = 0.008696 mole C2H5OH /Nm3 >>>> 0.017391 mole C /Nm3 >>>> 0.017391 *12 E3
= 208.69 mg C/Nm3
Pierre
Pierre Hi
Thank you for your super-fast response, and also for the clear and concise explanation.
That is really helpful !
Many thanks, Merci Bien !
Alex
[/indent]
Molecular weight Ethanol: 12*2+1*6+32*1=76 g/mol
Mass fraction of C is 12*2/76=0.316
Calculation : base 400 mg ethanol/Nm3 >>>> 400*0.316 >>> 126.3 mg C/Nm3
Analysers are notorious for wrong readings - always check that there is a recent calibration record.
Where possible, get a sample of vapor and send it to your lab for manual analysis.
Thanks a lot for your input Guys, really interesting.
Just FYI, my analyzer is a RAE Systems MiniRae3000.
The Calibration Gas is Isobutylene.
One can call up an extensive list of measured gases, the analyzer then applies a correction factor specific to the gas of interest.
In my case, Ethanol, this results in a factor of 10.0 and the result is displayed in mg Ethanol/m3. One then normalizes the result to obtain mg/Nm3
Going back to the Mass Fraction calculation @Pierreick,
<Calculation : base 400 mg ethanol/Nm3 >>> 400/ 46 E3 = 0.008696 mole C2H5OH /Nm3 >>>> 0.017391 mole C /Nm3 >>>> 0.017391 *12 E3
= 208.69 mg C/Nm3>
Is it possible to use the percentage: 208.69mgC/400mgE = 52.0725% - and apply this to other readings? For example: 950mg/Nm3 x 52.0725% = 494.6mgC ???
or would this be considered sloppy practice ?
This is new territory for me.
Thanks for your help,
Alex
