AlotLeftToLearn
European metals typically us codes such as +AT (solution annealed), +C, +1D in their standards such as EN 10088. When trying to find an equivilant material here in the USA, are using these codes considered the same here or is there another way that is more accepted here in the US?
Background: Stainless Tubes: I'm thinking A511 MT304 would be a good alternative for X5CrNi18-10+AT EN 10297-2. Do i need to specify in words that the metal should be solution annealed? can i use +AT or another code acceptable in the US?
