THooper
- Jul 19, 2001
- 90
We are working on a GE 300 hp DC motor. New brushes were installed in April and they showed 60% wear in a months time. Another set of brushes were installed and they had 50% wear in the last month. Concentricity has been checked on the commutator and there is about .001" run out. All of the mica segments have been undercut to .032" below the surface of the copper. Brush spring tension has been verfied at 5 =6 lbs per square inch and the springs are constant pressure springs. The commutator has been seasoned with a good film developed for lubrication and conductivity.
Each set of brushes that were installed were CPO brushes and ordered by the OEM part number so that the correct grade was installed. The brushes are sand seated to 100% contact with the commutator.
We have repaired a numerous amount of these motors over the past years and never experienced this type of problem.
Can a failure in the SCR package cause premature wear?
