Dear all,
I'm designing a finned tube exchanger (think a shell tube exchanger with extruded fins on tubes) as a condenser. Gas at approximately atmospheric pressure flows on the shell side, while an ethylene glycol-based (in water) solution runs on tube side at up to 50 psig (from pump) at low temperature to cool and condense the gas.
Question - would this exchanger considered a pressure vessel based on ASME Section VIII and need a U stamp?
The introduction part of the code says that among those excluded is the following:
The tube side contains a water-based solution (ethylene glycol), is nonflammable, and has a high boiling point, but I don't know if ASME Code Committee sees it this way.
Thank you everyone for your expertise.
ASME BPVC VIII-1 Edition 2015 U-1 (c) (2) (-f) said:a vessel for containing water under pressure, including those containing air the compression of which serves only as a cushion, when none of the following limitations are exceeded:
(-1) a design pressure of 300 psi (2 MPa);
(-2) a design temperature of 210°F (99°C);
