EXECUTING CODE DURING PACK AND GO
PAT44
12
CA
I would like to know if it s possible to execute a code on each files within pack and go. For exemple, if I pack and go an assembly, automaticaly when I ll press the save button, each files will have their properties deleted before they get saved.
Any ideas? Could be by using task manager or something...
Actualy, I wish the Author name to be deleted when a pack and go is made. I already have a macro that add this information when a new part or drawing is created but when a pack and go is made, I need this information to be deleted for the macro can proceed with the right information.
I know it sound complicated but if you can explain me how to do if I wish a macro to delete that author name each time I perform a pack and go. How to built that macro and how to do to autoexecute it on each pack and go.
Thanks for your time!
Thanks but I m using 2010 version of solidworks and I think api pack and go fonction only comes with the 2012 version..
If not, I m not able to make it run.
I'm not into API stuff, but I believe (at least some) API calls have been available for P&G since it's introduction in SW07.
Well in that case, you can have your macro modified that will open the files after P & G and then delete all the custom info.
Deepak Gupta
CSWE, CSWP, CSDA
SW 2011 SP5.0 & 2012 SP3.0
Boxer's SolidWorks™ Blog
