to answer your question re trying various jetting - yes of course we did, but please read on re this particular subject.
Should have given more tech info initially. As a 'newby' to this site I was not sure how much info to burden you with.
The engine is a small block chevy with an 8v-92 Blower (nom 436 cuins/rev - like an 8v-71 ).Initially set at 10% overdrive and for the last test 6% under. Fueling is by 2 off modified 750 Holleys with vac secondaries. One mod was to the Power Valve restrictions, increased by 0.010" firstly before considering larger jet increases. Jet sizes ended up nearly standard at 72 primary and 76 secondary. Other mods were larger needles at 0.120" plus larger shooters at 0.035". Power Valves at 6.5 each. 30 cc pumps. Purple vacuum diaphragm springs. Vacuum balance tubes between the two vac secondaries.
Heads are Edelbrock Victor Juniors modified to give a 7.7:1 compression ratio.
Cam is a solid roller lifter with timing of 244 deg duration Inlet and 252 deg duration Exhaust @ 0.050".
1.5:1 rocker ratio Inlet and 1.6:1 rocker ratio Exhaust.
112 deg LCA.
Valve lifts are 0.543" Inlet & 0.579" Exhaust.
Cam installed at 4 degrees advanced.
This engine spec was based on a previous engine. It did not have such bank to bank exhaust temp variations.
Tried various timing:- starting at 40 deg all-in made the engine 'pink'( detonate ) at only 4,900 rpm. Timing re- set to 30 deg ( as per my previous engine ) and again 'pinking', but higher at 6,000 rpm. Next was a safe 26 deg and this was fine upto 6,500 rpm. Positive 28 deg at 6% under would have been OK, but ran out of Dyno time.
I use an MSD Flying Magnet Crank Trigger.
Exhaust temperature readings I gave previously were at the 26 deg timing runs, with very little difference from 10% over and 6% under.
Max, indicated, boost at 6,500 rpm, at 10% over was 12.3 psi and 12.1 psi at 6% underdriven.
Inlet temps varied between 79 and 83 deg F ( 26.1 and 28.3 deg C ).
I noticed in this test session that the Blower was mad hot - I could not even touch it ( heat = pressure ? ). It was built to original specification clearances. The blower on the previous engine ran quite warm, but you could touch it.
BSFC figures :-
At 10% overdriven. At 6% underdriven.
3,400 rpm:- 0.068 lb/hph. 0.677 lb/hph.
3,500 rpm:- 0.646 lb/hph. 0.557 lb/hph.
4,000 rpm:- 0.599 lb/hph. 0.562 lb/hph.
4,500 rpm:- 0.568 lb/hph. 0.546 lb/hph.
5,000 rpm:- 0.508 lb/hph. 0.612 lb/hph.
5,500 rpm:- 0.653 lb/hph. 0.619 lb/hph.
6,000 rpm:- 0.616 lb/hph. 0.609 lb/hph.
6,500 rpm:- 0.642 lb/hph 0.607 lb/hph.
I can give the A/F ratio's, but how much info is required ?
One thing I can say is that after 6,000 rpm in both the 10% overdrive and the 6% underdrive the A/F ratio's went into lean between 13.2 & 14.4. The majority of time from 3,400 rpm to 6,000 rpm range the figures stayed in safer, but richer, 10.2 to 12.77 numbers respectively.
Comments on fitting a Methanol Injection system, injecting into the Blower inlet, under the Carbs, to try to cool the intake charge. Or maybe Water, or a combination of the two.
Previous use of Nitrous and C16, on a blown motor, brought the initial high inlet temperatures down to acceptable levels.
This car is used for Drag Racing as well as the road.
Power is 630 HP at 6,500 rpm and climbing before shut-off, with max Torque 600 lbsft occuring at 4,850 rpm.
Hope all this helps and if you need me to be more specific/clarify some aspects, please ask.
Many thanks.
