SpinningDorito
Computer
Let me start out by saying that this is my first post, so please, be gentle. I have searched the forum on my main points, I found the threads to be informative but I want more depth of knowledge.
The car is a mildly modified 1993 Mazda Rx-7 (engine code: 13b-rew), I have an Apex'i Power FC taking care of fuel maps and a Profec B Spec-II monitoring boost. The stock intake box is slightly modified stock intercooler (garbage), exhaust 3" from the turbos back with a high flow catalyst. All emissions gear is in place. Turbos are jury rigged non-sequential (parallel).
Which brings me to my question:
I'm going to be removing the TT assembly and finishing the non-sequential conversion- Entirely removing the flapper door that stops the secondary turbine from pre-spooling and boring out the wastegate. I considering going further and having the manifold extrude honed but the OEM cast piece has a history of cracking and extrude hone will only aggravate that.
I want to ceramic coat the manifold and turbine sections to lower radiant heat and potentially keep the heat in the mani. Is there anything that can stand rotary egts that could be sprayed on the interior of the manifold to prevent the manifold from heatsoaking and cracking?
I've been considering alcohol injection to lower my egts but a good kit is upwards of $1000, considerably higher than most enthusiast grade coatings.
Anyway- if you can decipher my post please share your thoughts.
Link to pictures of 20b-rew with separate pictures of it's very similar TT assembly:
Link to explanation of cracks:
