Hi all,
I Hva and existing deep beam with a section of 20x60 cm . the existing bottom steel is 2 T16 which is below the minimum required reinforcement by 20%. (must be 2T20).
I am adding a load on the beam, but the issue is the following.
The beam without any additional steel can support the existing load, should I retrofit the beam by adding 1 bottom layer or can I leave it as it is?
(the beam is 70 years old and no cracks are shown-f'c=22mpa fy=300 Mpa)
Thank you,
Thank you,
