erikuofo
- Apr 21, 2011
- 7
I've got an existing house constructed of cmu walls with #4 verts at 48" o.c. at the exterior up to about 10' to the plate height. The architect wants to extend the existing walls up to a new top of wall plate height to 12' and 14' in some cases. There is not any space to brace these walls at the new "hinge" that will be created. I will drill and epoxy dowels each face of wall as required to add up to 4' of vertical cmu, but wanted to know if any of you have had problems with cracking at the seam of the new interface or have had other problems with this issue.
Thanks,
Thanks,
