Expansion Joint manufacturer required ASME stamp certificate or not . 2
mechyp
30
Dear Experts
I am working on one enquiry of Heat-Exchanger that have Thin or Thick Expansion Joint.
All Heat-Exchanger Required to be manufactured under ASME Section Div -1 with U Stamp.
we have to sub-contract Expansion Joint as we have no facility to manufacture it.
since it will be used in U stamp Heat-Exchanger , Shall expansion joint Manufacturer require U stamp
Certificate ??
or
same can be wived,If Expansion Joint manufactured under provision of UG-11.
Thanks in advance
mechyp
In my opinion Expansion joint are welded components and require to be manufactured by an U stamp holder with a partial data report.
AMinati
mechyp, if a bellows (thin) joint, it will most likey be furnished complete, with Partial Data Report (U-2). If a flanged and flued (thick) joint, it will most likely be furnished as two (or more) F&F heads with PDR, with further fabrication by your organization. I've never seen either one furnished under UG-11.
Mike
Dear Mike/Aminati
As per UG-11(e) Second Sentence.
" In lieu of the requirement in UG-11(d)(4), the Certificate holder may subcontract to an individual organization not holding an ASME certificate standard pressure parts that are fabricated to a standard othre than an ASME product standard provided all the following conditions"
my interpretation that if my organization comply conditions UG-11(e)(1)to(10)then no need PDR and also ASME Certified Manufacture.
correct me if i'm wrong.
mechyp
mechyp, complying with UG-11(e)(1)to(10) means that YOUR organization assumes all responsibilities as the Certificate Holder. I am not certain that either type of joint would be considered as a "standard" part however.
Mike
You may have the smls or mfdwelded tube or pipe formed and then you do the welding of the flanges.you may talk to your AI for advise of what he will accept. I'm sure there are piping MFRS who hold ASME CERTs. Who already make certified ASME parts. Good luck.
