davidrdguez
- Apr 24, 2010
- 59
I am new here so I would like to greet everyone.
To start I bring a simple question, but I couldn't find information anywhere.
I have to design a water cooling system. In order to connect pipes, valves we use flanges.
This is going to be mounted in Germany. For example in one of the valves I have a DN80. According to some catalogues I see this 80 is not the inner diameter of the pipe attached to the flange. What does the 80 mean?
There are some existing flanges with outer diameter 285 mm, 8 holes and a bolt circle of 240 mm; I couldn't find a manufacturer with such type.
I was searching in Internet and in the forum, but I can't understand
Could you please explain me or give some link where this is explained?
Thanks in advance!
Cheers,
Thanks in advance!
Cheers,
