Explosion Proof RTD's
danw2
Industrial
I must have missed a previous thread, RTD's Intrinsically Safe,
Link
Just found it in a search.
(Keith) >Never seen an ExP RTD before. Seems likely to lag the poor thing horridly. I could see them wanting to change out ExP for two reasons. One would be having to run the requisite thick-wall conduit and bulkhead plugging hassles and the other would be maybe needing a more responsive sensor.
There's no lagging on the sensing element. Because the RTD is a 'simple apparatus', it's the screw cover head that is Class 1, Div 1 rated, not the sensing element.
Are you looking at a RTD or heat trace? In the past, I would spec a RTD in a thermowell. Then we would use C1, D2 wiring methods. If the "probe" had direct contact w/ a process, then I would go w/ IS.
Mike
