Explosive impact factor
corus
3,165
I'm trying to find the pressure which would cause a vessel to fail from a sudden increase in pressure, say by an explosion. Would an impact factor apply, and what value would be appropriate?
corus
Explosions, or rather "impulsively loaded vessels" are very complex. There is a special working group in the ASME Code Committees that is currently working on rules for this topic.
If I recall correctly, this gets into strain-rate-sensitive deformation - if the strain rate is very high in "tough" materials, then the instantaneous pressure could be higher than the steady-state pressure that would cause a vessel to "fail".
I would check out the ASME PVP Conference papers to see what's been done in the last 5 years. There has been work done by LANL - they were designing pressure vessels to test high explosives.
In addition to what TGS4 said, if your "sudden increase in pressure" is a deflagration rather than a detonation then VIII-1 Appendix H provides a bit of guidance. It also covers the difference between a deflagration and detonation.
ASME papers are available online. Here's a link to one small subset:
jt
You really need to define your explosion. There is explosive modeling software out there but it is difficult to obtain. You need to determine shock pressure & gas pressure. The shock will "reflect" inside the vessel so the impact load will repeat itself. I have used 2x the shock value as a design load in the past but vessel wall thickness must be considered as the load is so fast (applied & gone in the millisecond time frame) that the entire wall thickness may not react to the shock for a thick wall vessel. Look up some of the work Sandia has done in this regard - it used to be widely available.
